Problème d'affichage des disques dures - Disque dur - Hardware
MarshPosté le 03-06-2008 à 12:58:31
Bonjour, je travaille sur un serveur "Fujitsu SIEMENS Primergy TX 200 S3" pré-installer ubuntu server 7.10 je trouve une déférence comme je compare les disques existant et la facture d'achat dans la facture il ya "3 x Disques SAS de 73 Go et un controleur RAID 0-Channel pour support RAID5" et j'ai trouver dans le système la configuration suivante:
root@server:~# fdisk -l
Disk /dev/sda: 145.6 GB, 145693343744 bytes 255 heads, 63 sectors/track, 17712 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x0006eab3
Device Boot Start End Blocks Id System /dev/sda1 * 1 17338 139267453+ 83 Linux /dev/sda2 17339 17712 3004155 5 Extended /dev/sda5 17339 17712 3004123+ 82 Linux swap / Solaris
Marsh Posté le 03-06-2008 à 12:58:31
root@server:~# cat /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
# /dev/sda1
UUID=498862b3-2512-4822-9d92-11ccb09ccd1f / ext3 defaults,errors=remount-ro 0 1
# /dev/sda5
UUID=cc79fe92-3019-461a-9b1e-e10024196b9a none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec 0 0
root@server:~#
root@server:~# dmesg |grep sd[a-z]
[ 81.465787] sd 1:2:0:0: [sda] 284557312 512-byte hardware sectors (145693 MB)
[ 81.465942] sd 1:2:0:0: [sda] Test WP failed, assume Write Enabled
[ 81.465996] sd 1:2:0:0: [sda] Asking for cache data failed
[ 81.466059] sd 1:2:0:0: [sda] Assuming drive cache: write through
[ 81.466255] sd 1:2:0:0: [sda] 284557312 512-byte hardware sectors (145693 MB)
[ 81.466390] sd 1:2:0:0: [sda] Test WP failed, assume Write Enabled
[ 81.466436] sd 1:2:0:0: [sda] Asking for cache data failed
[ 81.466504] sd 1:2:0:0: [sda] Assuming drive cache: write through
[ 81.466570] sda: sda1 sda2 < sda5 >
[ 81.477710] sd 1:2:0:0: [sda] Attached SCSI disk
[ 83.237161] EXT3-fs: sda1: orphan cleanup on readonly fs
[ 83.430181] EXT3-fs: sda1: 9 orphan inodes deleted
[ 88.930285] Adding 3004112k swap on /dev/sda5. Priority:-1 extents:1 across:3004112k
[ 89.147549] EXT3 FS on sda1, internal journal
root@server:~#
root@server:~# parted
GNU Parted 1.7.1
Using /dev/sda
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) print all
Disk /dev/sda: 146GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number Start End Size Type File system Flags
1 32,3kB 143GB 143GB primary ext3 boot
2 143GB 146GB 3076MB extended
5 143GB 146GB 3076MB logical linux-swap
(parted) quit
Information: Don't forget to update /etc/fstab, if necessary.
root@server:~#
