Antec Solo - Boitier - Hardware
Marsh Posté le 10-01-2007 à 22:44:28
ReplyMarsh Posté le 11-01-2007 à 00:47:20
ReplyMarsh Posté le 12-01-2007 à 11:50:53
Je vote : "obiwan trouve qu'il est pas mal mais en préfère d'autres..."
Et doublon effectivement...
Marsh Posté le 10-01-2007 à 22:31:09
Voici le Antec Solo:
![http://www.hardwarelogic.com/articles/reviews/case/Antec_Solo_Mini_Tower/case_angle.jpg http://www.hardwarelogic.com/articles/reviews/case/Antec_Solo_Mini_Tower/case_angle.jpg](http://www.hardwarelogic.com/articles/reviews/case/Antec_Solo_Mini_Tower/case_angle.jpg)
![http://www.hardwarelogic.com/articles/reviews/case/Antec_Solo_Mini_Tower/case_inside_side.jpg http://www.hardwarelogic.com/articles/reviews/case/Antec_Solo_Mini_Tower/case_inside_side.jpg](http://www.hardwarelogic.com/articles/reviews/case/Antec_Solo_Mini_Tower/case_inside_side.jpg)
![http://www.hardwarelogic.com/articles/reviews/case/Antec_Solo_Mini_Tower/case_inside_hddcage.jpg http://www.hardwarelogic.com/articles/reviews/case/Antec_Solo_Mini_Tower/case_inside_hddcage.jpg](http://www.hardwarelogic.com/articles/reviews/case/Antec_Solo_Mini_Tower/case_inside_hddcage.jpg)
Solo Spec Sheet Model Solo
Case Dimensions 17.5"(H) x 8.1"(W) x 18.5"(D)
Drive Bays
- Front Accessible
- Internal
8
3x5.25", 1x3.5"
4x3.5" or 3x3.5" with HDD suspension
Expansion Slots 7
Cooling System
- 1 rear (standard) 120mm TriCool Fan with 3-speed switch control
- 2 front 92mm fan mounts (fans not included)
Main Board Size 12"(W)x9.6"(L)
Weight (net/gross) 25.3/30.3 lbs
11.5/15.7 K
Motherboards Standard ATX
Special Features
Internal mounts with rubber grommets
Optional HDD suspension system
Poly carbonate side panels to reduce noise
Advanced cable management system
Front USB/FireWire Ports
Package Includes 1 Tower Case
1 set of screws and motherboard standoffs
1 Installation manual
Alors, un excellent boitier silencieu de couleur noir et une facade en métal gris et pas trop gros! En fait, il est tout comme le P-150 mais en noir et sans alimentation et donc moin cher. Il intègre en plus des paneaux acoustiques sur les cotés interne du boitier. Il est doté d'élastique pour suspendre les disques dures afin de réduire les vibrations et ainsi le son, mais ils peuvent aussi être installer de facon standard.
Il inclus 1 ventilateur 120mm à l'arrière seulement mais il y a deux emplacement à l'avent (inclus filtres) pour y en mettre deux autres ventilateurs de 92mm.
Ce qui est aussi intéressent avec ce boitier c'est qu'il offre des visses à main qu'on peut dévisser sans l'aide d'un tournevis aux endroits stratégique pour facilité l'accès comme le paneaux d'accès à la carte mêre et à la grille avant pour enlever les disques dures ou pour le nettoyage etc.
Pour voir un test du boitier:
Message édité par offender le 12-01-2007 à 15:56:39
