[Topic Unique] Corsair AX750, AX850 et AX1200
Corsair AX750, AX850 et AX1200 [Topic Unique] - Alimentation - Hardware
Marsh Posté le 09-07-2010 à 15:54:27
MAJ : 11.09.10
Bonjour à tous
Intro :
Corsair lance ses premiers alimentations certifiées 80 PLUS Gold, les AX1200, AX850 et AX750 offrant respectivement des puissances de 1200, 850 et 750 Watts. Cette nouvelle série exclusivement modulaire affiche une efficacité de 90% en 115V et de 92% en 230V pour une charge de 50%, le bloc étant refroidi par un ventilateur 140mm en version 1200W et 120mm pour les 850 et 750 watts. Leur garantie est de 7 ans.
http://blog.corsair.com/wp-content/uploads/2010/06/AX1200-with-80-Gold-logo-web.gif
Descriptif de Corsair :
Unprecedented Power Protection
The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you.
A Fully Modular Cabling System
All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it’s time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling — the cables stay in place and connect to your new fully-modular Corsair power supply.
Incredible Efficiency
With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It’s earned the 80 Plus® Gold seal of approval, your guarantee that you’re making the right choice for smart, efficient power delivery.
Corsair Professional Series Gold AX1200 features:
    * Supports the latest ATX12V v2.31 and EPS 2.92 standards and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
    * An ultra-quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
    * 80 Plus Gold certified to deliver at least 90% efficiency at 50% load
    * Active Power Factor Correction (PFC) with PF value of 0.99
    * Universal AC input from 90~264V
          o No more hassle of flipping that tiny red switch to select the voltage input!
    * A dedicated single +12V rail offers maximum compatibility with the latest components
    * Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
    * High-quality Japanese capacitors provide uncompromised performance and reliability
    * Completely modular cable system allows you to use only the cables you need
          o Power supply upgrade and replacement is easy, as the cables only need to be disconnected at the power supply
    * Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis
    * A seven year warranty and lifetime access to Corsair’s legendary technical support and customer service
    * Dimensions: 150mm(W) x 86mm(H) x 200mm(L)
    * MTBF: 100,000 hours
    * Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
http://www.corsair.com/products/ax1200/80-plus-gold.gifhttp://www.corsair.com/products/ax1200/7YearWarranty.jpg
Caractéristiques principales :
    * Câblage totalement modulaire
    * Câbles plats pour un gain d'espace au sein du boîtier
    * 7 ans de garantie constructeur !!!
    * Normes ATX12V v2.31 et EPS 2.92
    * Ventilateur ultra-silencieux à double roulement à billes
    * Certification 80PLUS Gold pour un rendement supérieur à 90%
    * Détection automatique des tensions en entrée (de 90 à 264 Volts)
    * Rail 12V unique pour une compatibilité optimale avec vos composants
    * Protections contre les surtensions, variations d'intensité, sous-voltages et courts-circuits
Spécifications :
MAJ 17/08/10
Les Corsair AX750 et AX850 bénéficient bien d'un "Fanless mod" lorsqu'elles sont peu utilisées :
http://www.corsair.com/products/ax750/hybrid-fan.png
http://en.zimagez.com/miniature/75015.jpg
http://en.zimagez.com/miniature/85014.jpg
http://en.zimagez.com/miniature/12007.jpg
Courbes :
AX1200
Bruit :
http://www.zimagez.com/miniature/ax1200noise.png
Efficience :
http://www.zimagez.com/miniature/ax1200-efficiency.png
AX850
Bruit :
http://www.zimagez.com/miniature/ax850-noise.png
Efficience :
http://www.zimagez.com/miniature/ax850-efficiency.png
AX750
Bruit :
http://www.zimagez.com/miniature/ax750-noise.png
Efficience :
http://www.zimagez.com/miniature/ax750-efficiency.png
Tests :
Blog Corsair :
http://blog.corsair.com/?p=3253
Anglais :
Français :
Vos critiques :
Feedback de Pinto
Infos diverses :
Plusieurs retours attestent de bruits de couinement notamment pour la AX1200. Corsair semble avoir résolu le problème et propose de retourner son alimentation bruyante (et on peut ne la retourner après réception de la nouvelle) contre une silencieuse.
I want to mention that we have identified what is causing the coil whine issue and it only affects a very small number of shipped AX1200s. The vast majority should not have any issue whatsoever, and even the units that might experience the issue will only experience it in a certain situation.
That being said, we're fixing it on our side and anybody who has an AX1200 and has coil whine can contact me at redbeard@corsair.com and I'll get you a new unit. I'll make sure you don't have to be without a PSU during this time, as well, by providing advanced replacement.
Info ici : http://forum.hardware.fr/hfr/Hardw [...] m#t7570072
To be continued...
Message édité par 0b1 le 11-09-2010 à 12:14:22
Marsh Posté le 09-07-2010 à 15:54:35
Les vidéos :
AX1200 avec Tri Sli GTX480
Les photos :
http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2007.JPG http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2008.JPG
http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2022.JPG http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2030.JPG
http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2034.JPG http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2035.JPG
http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2044.JPG http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2064.JPG
http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2043.JPG http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2068.JPG
http://www.jonnyguru.com/modules/NDReviews/images/CorsairAX1200/DSCF2139.JPG
Message édité par 0b1 le 09-07-2010 à 16:18:50
Marsh Posté le 09-07-2010 à 15:54:40
Le package :
http://i845.photobucket.com/albums/ab19/Brian30102/Corsair%20AX1200%20PSU/pciecables-4.jpg
http://i845.photobucket.com/albums/ab19/Brian30102/Corsair%20AX1200%20PSU/satacables-5.jpg
Date de lancement :
Les AX750/AX850/1200 sont désormais disponibles (LDLC & TopAchat).
Le prix : (au 16/08/10)
AX750 : 158,96 €
AX850 : 180,95 €
AX1200 : 268,96 €
Message édité par 0b1 le 23-08-2010 à 21:43:34
Marsh Posté le 10-07-2010 à 05:39:27
MErci ob1 pour ce topic ... elle veut un petit drapal  ;p
Marsh Posté le 10-07-2010 à 09:27:18
Déjà dispo chez LDLC
  AX750 au prix de 170,96€
  AX850 au prix de 193,96€
AX1200 au prix de 289,96€
Garantie 7 ans par Corsair
En informatique, si tu attends la prochaine technologie... Tu n'achètes jamais rien...
Marsh Posté le 10-07-2010 à 10:59:49
 pas dispo juste annoncé  :ange:
mon topic de vente
Marsh Posté le 10-07-2010 à 11:04:42
AX1200 si... ah mince non... délai de 15 jours... autant dire qu'on ne sait pas  :lol:
Désolé
Message édité par lauleg le 10-07-2010 à 11:05:31
Marsh Posté le 10-07-2010 à 11:10:46
en comparant la AX850 à la HX850 (certifié officiellement Silver mais qui serait Gold), vu la différence de prix, je ne suis pas sur que le consommateur s'y retrouve réellement :/ pas tant de différence que ça ?!
même garantie, rendement un poil meilleur pour la AX apparement, cablage totalement modulaire pour la AX (de toute façon les cables non modulaire de la HX doivent être branché)
Message édité par Alis_70 le 10-07-2010 à 11:12:57
Marsh Posté le 10-07-2010 à 11:35:42
le full modulaire c'est bien si les gens veulent faire du murder mod sans faire sauter la garantie  [:markdavis]
mon topic de vente
Marsh Posté le 11-07-2010 à 14:51:54
Désolé
Moi je vois dispo vers le 25/08 :/
Marsh Posté le 11-07-2010 à 14:55:07
Oui oui... désolé... j'étai tellement heureux de les trouver (avec un prix) que j'ai été trop vite...
Marsh Posté le 11-07-2010 à 20:03:25
Pas de mal
Pas beaucoup de retours pour le moment pour les AX750 et 850. Tous les tests effectués l'ont été sur la vitrine de la gamme pour le moment : AX1200.
Marsh Posté le 05-08-2010 à 15:26:18
Ce serait super si un comparo sortait avec la Coolermaster Pro Gold 1200W :)
2 alimentations gold de 1200w, les 2 en câblages plat... une belle opposition pour des prix quasi similaires
Mon feed-back - Mon topic
Marsh Posté le 05-08-2010 à 16:07:16
Les Cooler Master sont de très bonne facture mais souffrent de fluctuation de tensions d'après ce que j'ai pu lire.
A côté de ça, les Corsair sont garanties 7 ans et sont modulaires à 100% :love:
Marsh Posté le 05-08-2010 à 17:54:42
http://jonnyguru.com/modules.php?n [...] y&reid=189
Pour la Corsair
http://jonnyguru.com/modules.php?n [...] y&reid=193
Pour la Coolermaster
On peut comparer directement les résultats ...
Conclusion Corsair Winner :o .
Message édité par havoc_28 le 07-08-2010 à 01:53:40
Marsh Posté le 06-08-2010 à 11:12:22
Pour la Corsair
http://jonnyguru.com/modules.php?a [...] y&reid=193
:D
Intéressant, je n'avais pas pensé à les opposer directement.
L'AX1200 est notée 10/10 en terme de performance contre 8/10 pour la Cooler Master. Impressionnant une telle différence sur une si petite échelle (20% mieux notée).
 [:implosion du tibia]
Marsh Posté le 10-08-2010 à 15:46:07
Les AX750/AX850 sont disponibles chez LDLC :jap:
Marsh Posté le 13-08-2010 à 16:21:17
Drapal, et merde, moi qui pensait avoir trouve mon graal avec la seasonic X-750 ....
Chic not Geek
Marsh Posté le 13-08-2010 à 16:30:46
http://www.gnd-tech.com/main/conte [...] the-Market
Mouhaaa voila qui repond a mes interrogations, les corsairs AX sont basees sur la plateforme des Seasonic X-series, a voir maintenant s'il vaut mieux faire confiance a Dieu plutot qu'a ses anges ;)
Chic not Geek
Marsh Posté le 13-08-2010 à 19:32:10
Mouhaaa voila qui repond a mes interrogations, les corsairs AX sont basées sur la plateforme des Seasonic X-series, a voir maintenant s'il vaut mieux faire confiance a Dieu plutot qu'a ses anges ;)
ça dit que les AX750/AX850 sont basées sur une plateforme seasonic Pour la AX 1200 c'est Flextronics mais ça n'enlève rien à ces qualités .
Donc on ne peut pas dire que les Corsairs AX sont basées sur des seasonic sans préciser que la AX 1200 c'est Flextronics  :whistle:
Après le choix entre une AX750/AX850 et les seasonic X Series , vu que c'est la même base autant faire son choix sur le prix / sav . 2 ans de plus chez Corsair et le sav de qualité , aux usa le sav seasonic à l'air tres bien , mais ici en europe s'il faut passer par un distributeur ou que sais je ce n'est peut être pas forcement du même acabits  .
Message édité par havoc_28 le 14-08-2010 à 08:46:17
Marsh Posté le 15-08-2010 à 16:24:11
Merci pour les infos (j'ai adoré le test de JonnyGuru, toujours complets et détaillés, écrits dans un style propre au site).
Cette alimentation a l'air d'être un vrai bijou. Les câbles entièrement noirs, avec gaîne de qualité apparament supérieure à ce que l'on voit habituellement, est un plus grandement apprécié.
Les AX1200 arrivent bientôt en UE. J'en ai trouvé une en Allemagne, sur HardwareGeier -- page produit -- à "seulement" 242.66€  (meilleur prix en UE) et en stock dès Mercredi, 18 Août 2010. Points à noter :
  • 20€ de FDP : il vaut mieux les rentabiliser en commandant autre chose au passage.
  • Paiement par virement bancaire : ne pas oublier de préciser le numéro de la commande dans l'intitulé de l'opération côté destinataire du virement.
  • Le site étant en Allemand, il est donc préférable de le visiter via Google Chrome et traduire les pages à la vollée lorsque la barre supérieure le propose.
J'en ai commandé une, nous verrons ce que ça donne.
Message édité par Roman2K le 15-08-2010 à 16:28:24
A vendre | Feedback
Marsh Posté le 15-08-2010 à 16:29:32
Mouai c'est quand même super chers c'est bêtes là.
Ya-t-il la fonction fanless à faible charge comme sur les seasonic ?
Marsh Posté le 15-08-2010 à 18:17:26
D'apres les photos que j'ai pu voir je crois me souvenir que les cables ne sont justement pas gainés, par contre ils sont plats, ce qui peut etre arrangeant pour des gens ayant des boitiers avec des facades droites pas tres spacieuses
Chic not Geek
Marsh Posté le 15-08-2010 à 21:52:53
La moitié des câbles sont gaînés d'après les photos postées par 0b1 ci-dessus (ici).
A vendre | Feedback
Marsh Posté le 16-08-2010 à 10:21:19
Elles sont sensiblement identiques, bien que la Corsair est garantie 2 années de plus et les câbles sont bien mieux réussis : plats et gaînés :love:
La AX750 est vendue moins cher que la Seasonic X-750.
Garantie 2 années supplémentaires.
J'appelle pas ça cher moi :/
C'est le prix de la qualité.
Marsh Posté le 16-08-2010 à 10:24:30
+1.
Ca vaut pour les >= 1200W également. La Corsair est juste légèrement plus chère que les Be-Quiet et Cooler Master, et encore, ça dépend des boutiques. Et même si c'était le cas partout, la différence (+10€ maxi.) serait justifiée.
Message édité par Roman2K le 16-08-2010 à 10:24:35
A vendre | Feedback
Marsh Posté le 16-08-2010 à 10:25:37
Elle est annoncée le 25/08 chez LDLC, un peu plus cher apparemment. Reste que tant qu'elle n'est pas sortie son prix n'est sans doute pas définitif.
http://www.ldlc.com/navigation/cat [...] 292_6_val=
Message édité par 0b1 le 16-08-2010 à 10:26:12
Marsh Posté le 16-08-2010 à 10:31:08
0b1 a écrit :
Elle est annoncée le 25/08 chez LDLC que chez HardwareGeier, un peu plus cher apparemment. Reste que tant qu'elle n'est pas sortie son prix n'est sans doute pas définitif.
Il y a aussi moins de frais de port chez LDLC. A noter qu'ils ont des prix intéressants sur les produits Corsair en ce moment, ils doivent avoir une sorte de partenariat étant donné les bandeaux publicitaires pour Corsair tournant sur leur site. On verra bien si les prix fluctuent pour les AX d'ici les arrivées en stock en France.
Message édité par Roman2K le 16-08-2010 à 10:31:19
A vendre | Feedback
Marsh Posté le 16-08-2010 à 12:50:18
Moi qui devait prendre une coolermaster silent pro gold 700w je vais attendre sagement le test de la 750w de la corsair AX.
Marsh Posté le 16-08-2010 à 19:19:06
[:blueflag]
Marsh Posté le 16-08-2010 à 19:38:55
Edit : ha oui en effet les cables atx pcie etc sont gaines ET plats, joli  :D
Message édité par lovingbenji le 16-08-2010 à 19:41:12
Chic not Geek
Marsh Posté le 16-08-2010 à 20:14:26
Ils sont pas plats, ils sont justes unis. T'as la vue qui baisse Benji  :pt1cable:  ça se voit à la forme de la gaine thermo. Par contre la loose il y a des ferrites sur les pci-e pour le ripple( comme sur la coolermaster et ma thermaltake), galère pour "sleever" les câbles  :(
Marsh Posté le 16-08-2010 à 20:17:01
Bon topic, 0b1 ! :sol:
C'aurait été encore mieux si tu avais donné son lien en méta-topic ! ;)
Penses-y la prochaine fois que tu crée un topic, s'il te plaît :jap:
Marsh Posté le 17-08-2010 à 11:12:37
Tu parles du morceau de plastique?
Je l'ai fait sauter pour gaîner mes câbles PCI-E de HX750, pas de difficulté majeure :jap:
C'est quoi?
Je peux le faire encore ou c'est trop tard?
Marsh Posté le 17-08-2010 à 11:15:15
MAJ : Il y a bel et bien un "Fanless mod" sur les AX750 et AX850 du moins :
EDIT : Fixed
Message édité par 0b1 le 17-08-2010 à 11:28:18
Marsh Posté le 17-08-2010 à 11:24:36
Ajout des courbes de bruit et d'efficience :jap:
Marsh Posté le 17-08-2010 à 11:26:52
0b1 a écrit :
C'est quoi?
MP :jap:
0b1 a écrit :
MAJ : Il y a bel et bien un "Fanless mod" sur les AX780 et AX850 du moins :
 :heink:  :lol:
En tout cas, c'est bien de constater que les nouvelles alims ont de plus en plus un mode passif lorsque la charge est faible...
Cela dit, c'est d'une utilité limitée, si l'on prend en compte que ce sont des alims HDG et donc chères, et qu'une alim onéreuse va de pair avec un bon PC, et que les ordis puissants consomment toujours pas mal de jus !
Message édité par Zack38 le 17-08-2010 à 11:28:54
Marsh Posté le 17-08-2010 à 11:27:47
Ah c'est cool ça ^^
Marsh Posté le 17-08-2010 à 11:31:48
Zack38 a écrit :
 :heink:  :lol:
C'est corrigé, merci.
Alimentations pour configuration HDG oui, c'est certain.
Mais il ne faut pas oublier qu'elles peuvent aussi être en idle ces config, et c'est toujours agréable d'être dans un grand silence lorsqu'on est sur le bureau ou sur le net.
EDIT : 20% de 850W ça fait quand même plus de 150W.
Sur une alimentation à haut rendement, on peut tabler sur du 200-250W à la prise en fanless. Je trouve ça correct, suffisant pour de l'idle.
Message édité par 0b1 le 17-08-2010 à 11:33:47
Marsh Posté le 20-08-2010 à 11:52:29
A propos de HardwareGeier et leur AX1200 soit-disant disponible Mercredi 18 août 2010. Je l'avais commandée ainsi qu'un SSD OCZ Vertex 2 (et payé par virement bancaire).
C'est du grand n'importe quoi.
Avant la commande :
  • La AX1200 devait arriver le 18 en stock
  • Le Vertex 2 était déjà en stock
Une fois le 18 arrivé :
1. Je leur envoie un e-mail pour savoir si tout est maintenant disponible et si la commande peut partir.
  a. Pour la AX1200, ils me disent qu'ils n'en savent rien et que le fournisseur n'avait pas d'informations plus précises.
  b. Ils ont ignoré la question pour le Vertex 2.
2. L'après-midi, la date de disponibilité de la AX1200 *et* du Vertex 2 (produit sorti depuis bien longtemps) devient "inconnue".
3. Devant ce manque de sérieux, je demande d'annuler la commande. Ils le font assez rapidement.
4. Je pensais que le remboursement était évident, mais j'ai du le demander explicitement car ils ne m'ont pas demandé mes coordonnées bancaires... Je leur donne donc un RIB + IBAN (PDF de la banque) mais comme apparament ils ne comprennent ni le Français ni l'Anglais, je dois leur donner dans leur format. Ce que j'ai fait.
5. Ils ne me tiennent pas au courant du remboursement : je veux juste savoir quand ils l'ont/auront effectué. Mais non, tant que je ne demande rien, je n'ai pas d'information.
6. Ils ne répondent qu'aux e-mails initiaux, et pas aux réponses. Obligé d'envoyer un nouvel e-mail avec titre différent pour chaque question afin qu'ils répondent.
7. Et il faut voir les réponses... Ils lisent les e-mails une fois moulinés par un traducteur en ligne, et pas un bon car ils répondent en passant leur réponse par ce même traducteur; et le résultat est horrible. Exemple :
Dear Mr. novel Le Négrate,
the amount is as fast as possible refunded as desired. If a bank credit transfer is accomplished, the amount is according to experience credited to your account within one week. Please consider that our coworkers the Rückerstattung during the working days (Mo-Fr) would drive through. At sunning and holidays our bookkeeping is not occupied.
Thank you for your understanding.
Yours sincerely
(Dans la première ligne, le mot "novel" est censé être mon prénom (Roman), qui apparament veut dire "roman" en allemand puisqu'il a été traduit en "novel" par leur traducteur.)
Bref, ne jamais, *jamais* commander sur HardwareGeier, malgré les prix attractifs.
J'espère que mon retour d'expérience servira à quelqu'un d'autre. C'est jusque là le seul site allemand avec lequel j'ai rencontré un soucis.
Conclusion concernant la AX1200 en particulier : il faut la commander sur LDLC.
Message édité par Roman2K le 20-08-2010 à 12:00:41
A vendre | Feedback
