Nvlddmkm.sys
Nvlddmkm.sys - Carte graphique - Hardware
Marsh Posté le 06-02-2013 à 17:06:43
Salut a tous, je rencontre unprobleme qui devient a la longue insupportable il s'agit d'un reboot de windows qui survient lorsque je lance un jeu 3D ou de facons tres aléatoires sans lancer de jeu .....
Voici le rapport de Whocrashed :
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\windows
CPU: GenuineIntel Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 6423900160 total
VM: 2147352576, free: 1950470144
Crash dump directory: C:\windows\Minidump
Crash dumps are enabled on your computer.
On Wed 06/02/2013 15:52:22 GMT your computer crashed
crash dump file: C:\windows\Minidump\020613-20904-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x929ADC)
Bugcheck code: 0x116 (0xFFFFFA80056C4350, 0xFFFFF88007DD1ADC, 0xFFFFFFFFC000009A, 0x4)
Error: VIDEO_TDR_ERROR
file path: C:\windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 310.90
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 310.90
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 310.90 , NVIDIA Corporation).
Google query: NVIDIA Corporation VIDEO_TDR_ERROR
crash dump file: C:\windows\memory.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF88007DD1ADC)
J'ai déja tenté la methode qui consiste prendre le driver et l'extraire et l'underclock mais aucuns résultats ....
J'espere que vous pourrez me venir en aide  :jap:
Bonne journée
Marsh Posté le 06-02-2013 à 17:09:17
Ta cg est peut etre en train de mourir
Ou t'as des rams pétées
Ou l'alim
Message édité par coma13 le 06-02-2013 à 17:09:25
Marsh Posté le 06-02-2013 à 17:12:05
Sa me ferait chier car l'ordi a même pas 1an .....
Marsh Posté le 06-02-2013 à 17:56:28
ou alors un conflit avec le gpu integré...
ou bien un probleme de temperature cg/cpu/chipset
L'erreur 116 est liée a la carte graphique... pas un prob de ram...
Sans pour autant etre un probleme de carte video hs.
Dejà, commence par verifier pendant tes parties de jeux:
1- les frequences de fonctionnement du cpu et du gpu...
Si l'un ou l'autre, ou les 2 font le yoyo, ça peut etre une cause ou une conséquence a tes problemes.
2- les temperatures... toutes les temperature -> gpu/vram/mofset cg - cpu - mofset cm - chipset cm (northbridge & southbridge)
3- les voltages -> cpu/chipset - gpu, etc...
Il se peut que la carte mere, via le bios, envoi un certains voltage liée a la cg/pcie insuffisant -> essai de faire une recherche web sur les options de voltages de ta carte mere... Le but est d'en trouver au moins 1 lié a l'alimentation de la cg ou d'un composant de la mobal gérant la cg (sur chipset x58, il y en a 3).
PS: lorsque l'on overclock son cpu, il est frequent d'avoir cette erreur 116
I7 920 - EVGA Classified X58 3 way-SLI - GTX670 EVGA FTW - 3*4go DDR3-2000 - BenQ XL2420T - 3D 120Hz 1920x1080 - Win7 x64
