Carte mére Asus Rampage Extreme X48 et SLI
Carte mére Asus Rampage Extreme X48 et SLI - Carte graphique - Hardware
Marsh Posté le 02-12-2011 à 00:45:40
Bonjour, je voudrais savoir si il est possible de faire un SLI de GTX 470 avec le SLI PATCH sur une Asus Rampage extreme X48 Socket 775 qui est normalement prévu pour le crossfire.
J'ai lu sur ce topic que c'était possible de le faire:
http://www.bios-mods.com/forum/Thr [...] xtreme-x48
RE: sli on asus rampage extreme x48
You can run SLI on this board...
I'm using 2x 285 GTX in SLI and it work perfectly, simply do the following:
"Install 2 identical Cards with SLI support "or 2 with the same GPU" then:
1- Uninstall and remove all sli mods and patches "Do not restart"
2- Uninstall and remove intel's Chipset driver "Do not restart"
3- Get "Diver Sweeper" and install it - here is a link: Driver Sweeper 2.5.0
4- Using Driver Sweeper, check and clean every thing named Nvidia "Drivers, Physix...etc"
5- When done, make a restart then install the latest Chipset Driver from intel
6- Download SLI_Patch 1.2 beta from here: SLI-Patch-1.2b
7- Disable UAC - Control Panel -> User Accounts & Family Safety -> User Accounts -> Change User Accounts Control settings -> Move the slider down to the bottom and click Ok
8- With UAC Disabled run SLI Patch 1.2 and click install
9- Restart now and you should see a boot menu with 2 options ( Windows 7 & Windows 7/......SLIPatch X64 ) choose the patched one
10- Install Nvidia Drivers version 260.xx "i'm using 260.99 32bit Xtreme tweaked" you can find those tweaked drivers at http://www.tweakforce.com
11- After installing the drivers go to Nvidia Control Panel then under 3D Settings click Set SLI and Physix
12- Under SLI Configuration, choose Maximize 3D Performance and click Apply
13- To see SLI usage indicator in your games click 3D Settings menu from the top of Nvidia Control Panel and check "Show SLI Visual indicator
et le site pour le SLI patch est ici:
http://slipatch.com/
2eme question: j'hésite à acheter une GTX480 et je voudrais savoir si je peux la coupler en SLI avec une autre GTX 470 sur cette même carte mère et avec le SLI PATCH.
--- Mon Feed-Back ---
Marsh Posté le 04-12-2011 à 17:42:03
Marsh Posté le 04-12-2011 à 17:43:12
Si je ne me trompe pas pour le SLI (contrairement au crossfire) il te faut absolument deux cartes graphiques identiques, donc à voir aussi avec ceux qui s'y connaissent mieux que moi. Déjà savoir ça avant de se lancer dans un SLI Patch.
Marsh Posté le 04-12-2011 à 18:12:17
normalement on peut coupler 2 carte d'une même séries GTX 4XX par ex, mais seulement la carte la plus performante est bridée sur les performances de la 2ème, sinon ca fonctionne, mais je posai cette question parceque je pouvais avoir une GTX 480 pour le même prix qu'une 470 donc je me demandais si on pouvait cette manip avec le patch sli.
Message édité par m0anis le 04-12-2011 à 18:12:55
Marsh Posté le 05-12-2011 à 18:30:01
Non je suis pas sure, mais je ne pense pas que tu puisses faire un SLI avec une gtx480 et une gtx470, à vérifier sur le site de nvidia.
De mémoire, c'est un hybride SLI que tu peux faire, c'est à dire une carte pour jouer par exemple la gtx480 et une carte dédiée physx, la gtx470.
"4bsynthe, n'est 4bsente que toi!"
Marsh Posté le 05-12-2011 à 19:31:41
de toute façon finalement j'ai acheté 2 GTX 470 (j'en ai déja une, j'attends la 2ème) donc maintenant reste plus qu'a savoir si je vais pouvoir les faire fonctionner en sli avec le slipatch
