Pb au boot avec Radeon 9700 - Carte graphique - Hardware
Marsh Posté le 26-05-2003 à 15:24:29
je cherche je cherche ...
sur le site de tonton ATI j'ai vu 2 trucs en rapport avec mon pb:
http://www.ati.com/support/infobase/4069.html
RADEON 9700 PRO 128MB: No display on POST until Windows loads
This issue affects some Radeon 9700 PRO 128MB products configured on an ASUS P4T533 - C motherboard. However, other motherboards may also be affected.
In some instances, no display will be present on the initial bootup or POST screen. However, once the operating system loads, the display will return.
Most systems are unaffected.
Please ensure that the article listed below does not apply in your particular instance:
Corrupted display on cold boot
et celui là
http://www.ati.com/support/infobase/4075.html
RADEON 9700 PRO 128MB - Corrupted display when system is started
A corrupted display may be noticed under the following conditions:
A system with a RADEON 9700 PRO 128 MB
The system has been started
Only a small number of configurations may be affected.
Customers report changing the power supply in an affected system resolves the corruption. If another power supply is available, it is advised to install it for testing.
A 300 Watt power supply or greater is recommended to ensure normal system operation where a number of other internal devices are installed.
bref je redetaille mon système
alim enermax 430w
CM: Abit NF7-S
RAM: 2*256 DDR Samsung PC3200
CG: Club3D Radeon 9700
SCSI: Adaptec 2940AH
CS: SB Live 5.1
HDD: Maxtor 80go + WD 40go + Quantum 2.1go SCSI
CD: Pioneer SCSI 24x
CDR: Yahama 8824 scsi
bref si il faut une alim + puissante pour faire marcher tout cela je comprend plus ....
Est ce que en augmentant la tension du port AGP (1.5 à 1.X ?) j'ai une chance de changer qq chose ? (sans rien bruler surtout ?!!!!)
Mais peut être que je m'inquète pour rien et que c'est normal de ne pas avoir d'image pendant le boot ....
Ce que j'aimerai savoir c'est si je suis tout seul a avoir ce pb ou si il est courant ...
Marsh Posté le 26-05-2003 à 15:28:03
T'as bien branche la carte directement sur l'alim avec le connecteur molex ?
Dans ce cas, je pense que ca serve a quelque chose d'augmenter le voltage AGP...
Marsh Posté le 26-05-2003 à 15:57:08
oui oui j'ai bien branché la carte avec le connecteur molex. D'ailleur si je ne le fait pas j'ai bipbipbiiiiiiiiiip avec un gros message rouge qui me demande de le faire.
Marsh Posté le 26-05-2003 à 11:26:19
ma config
Abit nf7-s (dernier bios en ligne)
2*256 ddram
XP 2400+
radeon club3d 9700
alim enermax 430w
Adaptec 2940AU
XP SP1
mon pb:
-->au démarrage à froid, je n'ai le signal video qu'après 5/6 s, juste assez pour voir le bios de l'adaptec. J'ai résolu (en attendant explication) en mettant dans le bios fastmachin en disabled afin que le test mêmoire dure + longtemps ce qui me permet d'avoir la video avec le test mémoire normal , les HDD le resumer du post boot ...
-->au démarrage à chaud (reset), c'est pareil et en + de temps en temps des caractères tronqué (décallage de pixel).
--> sous windaube pas de pb, et les jeux vont bien ...
Ma question: est ce normal, est ce que ma carte est shoutée ( )
En tout cas, venant comme beaucoup de chez tonton Nvidia, cela commence à me les nerfs ...
Merci à tous pour vos préciseuses réponses
