Import .sat file problems in DIALUX evo 5
Import .sat file problems in DIALUX evo 5 - Infographie 3D - Graphisme
Marsh Posté le 29-05-2015 à 09:42:03
Hello!
I tried to import a .sat file as an object in my Dialux evo 5 project but after 5 hours downloading, the program didn't respond. The .sat file is very heavy (283 000 KB). It is an architect file with buildings, and landscape. I need to work on this base to focus my work only on the light design instead of architecture design.
My desktop PC: i7 - 4790 // 8GB 3DD RAM// Nvidia GTX 750 ti 2GB
Would it be better if I import a .3ds file?
How can I convert a .sat file to .3ds file without using 3DSMAX?
Also, I have imported the same file in 3D dwg as a drawing but it display only a Wireframe model instead of a shaded model.
Do you have a solution to my problem?
